Samsung tab pro sm-t525
Hello,
i have a samsung tab pro sm-t525.
device charge bad so i replace 2x the charging port and the batterij but still same problem.
device stops charging after 2-3 min.
Hello,
vdb consulting since you already changed the battery and the USB connector (hopefully it is a good repair and the parts are functioning normally) you want to go ahead and check the charging circuitry according to the schematic
Then it’s probably a battery issue here is the replacement.Remplacement de la batterie du Samsung Galaxy Tab Pro 10.1
No, we change the battery also, no result..
Stops everytime with charging
Did you get them from a good place like ifixit?
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 242
