Aller au contenu principal
Smartphone designed by Xiaomi in the Redmi Note line.
Questions au sujet de 49 Voir tout
Redmi note 4 charging issue :
1.It is not continuously charging …….after 5 min or in few min it will automatically charging stopped….after i re plugged its charging ..and again same issue.
one day its charging up to 3%. fullday it connected battery indication is glowing but at the end same 3%
what is the issue any suggestion vradhakrishnan25@gmail.com
please help me
i tried many things:
1. I replaced new battery….
2. mobile factory reset by “mi pc suite mode”
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Try to resolder the USB port pins.
If you have a multimeter it is more easy to locate the problem. If you have one let me know and i will tell you where to start.
Indice 4
6 commentaires:
Thank you bro .....the mobile power port pin is sometime shacking......i think it is broken..
thanks for the suggestion....
par
i'm glad it helped you
par
yes bro the issue is fixed as your suggestion .....i given to service center again ..they replaced the mobile power port pin now its working fine .......thank u bro........
par
Thanks for the blog! here you will also find many useful blogs https://www.bpwltd.com/hangover-tamil-du...
par
Afficher 1 commentaire en plus
Ajouter une réponse
Radhakrishnan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 60
Total : 9,204
