Aller au contenu principal
The Asus Vivobook Max X541SA-PD0703X is a portable personal computer maufactured in May2017 by ASUS.
ASUS X541S Clear CMOS
On the motherboard of ASUS X541SA, I do not see the battery. Therefore, I can not reset the CMOS settings
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
Alex AWE CMOS batteries are pretty much a thing of the past. For the last 5-10 years the CMOS information can no longer be reset by that method.
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi Alex
Try this method, turn on the computer and access BIOS
Please visit this link below.
https://pastebin.com/raw/L3c3rySj
Subtract current year and get the password
e.g.
2019 - 10 = 2009
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
  • At the password prompt, press alt+r
  • Take note of the date displayed. For me it was 2017-05-11
  • Use Ctrl+F to search the paste bin for your month and date. I used "-05-11"
  • Use the codes you find until one of them works. Mine was the same code as 2007-05-11 from the paste bin.
  • It looks like the codes might repeat every 10 years. So I would suggest starting with the month and date combination from 10 years prior to whatever date is displayed after you press alt+r.
Indice 4
5 commentaires:
This page is no longer available. It has either expired, been removed by its creator, or removed by one of the Pastebin staff.
par
I have the same problem, could you find a solution?
par
This doesn't work for me. There is no response when I press Alt + R.
par
It works! I have a X541N, i just cleared the cmos password using this method. Thank you very much!
par
No response on ALT+R with an Asus X541SA
Indice 1
3 commentaires:
I'm having the same problem. I can get past my user password but not the admin and I've tried to Pastebin. The only option I know of is to send it to ASUS or replace the motherboard.
par
par
me too, solved?
par
Ajouter une réponse
Alex AWE sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 31
Total : 4,605
