Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
thanks for answering
Please look at this question: What are Professionals Using for Screen Cleaning
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 479
5 commentaires
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
par mayer
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
par Amr Ateef
If its pure, then you should use it. My answer is YES!
par Kon Dev
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
par John Potter
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
par Amr Ateef
