you should be able to use your old iPhone without SIM card, as if it were like an iPod touch
I did this with my 3G when I first got my 3GS - for a while my kids were using the old 3G with all my same apps only just using WiFi, while I used the original SIM card in my new 3GS (I've since sold the old phone).
the key is that the old phone must be left activated. In other words, if you do a complete restore of the old phone to wipe it clean, it will not even operate as an iPod until you activate it with your SIM card (like you did when you first got it). but after that it's ok to use without SIM card.
*EDIT* - I just found an Apple support document that shows a difference between original iPhone and later models regarding this issue.
according to the doc, the 3G and 3GS will operate without a SIM as I have described above, i.e. once activated you can remove the SIM card and it will work as if it were an iPod touch
However the original iPhone (which is what the OP has) behaves differently.
it says to use the iPhone without active cellular you need to have the original SIM card it was activated with installed *even if the SIM card is now inactive*
so I think a solution (without jailbreaking) for your original iPhone would be to somehow get AT&T to switch your cellular account to a new SIM card (your dog ate your old SIM card, perhaps?), then leave the old now-inactive SIM card in the original iPhone? unfortunately this would not be a zero-cost method...
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
I appreciate the answers below.
FYI, simply putting in a new sim card didn't work. The phone must be activated. One can not activate a new sim card without starting a separate AT&T account for the phone (I don't want to spend the money).
I bought and tried a jailbreak program which was an miserable experience (a huge waste of time that ended in failure).
I re-read the advice from BAC. I was trying to avoid switching the sim card from new phone to old phone for fear that something will go wrong with my new phone when I put the sim card back in the new phone. But the apple support doc does suggest this is okay but doesn't state it directly.
So, the question is, if I take sim card A, out of iPhone B (3G), put sim card "A" into original iPhone A (1st gen), activate iPhone A, take sim card A out of iPhone A and put it back into iPhone B, will iPhone B work as normal.
I will post this as a new question.
Thanks
par drprice
