Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
My LG tv will not turn on and the red light stays on
we have not had the tv on in 4 months as it is a summer home but there has been some severe storms but when we went to turn it on the red light is on but the set will not turn on..either by remote or by power button…we have unplugged it and we even plugged in in to the wall and off the power strip still nothing,,,could this have been fried by a power surge? It is a 55 inch set
Répondre à cette question J'ai le même problème
Indice 8
1 commentaire
These remotes are made to fail it seems. Same issue. Loads of other people experiencing the same.
My On/Off button stopped working.
New batteries. Nothing.
So I took it apart, cleaned it thoroughly, reassembled it. Nothing.
Then i figured what else could it be? Tried paring it again . Home + back button for 5 seconds. Unpaired.
Long press scroll wheel should result in 3 flashes of the on/off button. It does no such thing. It stays red. Indefinitely.
Result? An unpaired remote that can't be paired again. Genius engineers at LG.
Unplugging the tv didnt do anything either.
Will leave out the batteries for the night that helped some I read.
par
Ajouter un commentaire
10 Réponses
Réponse la plus utile
Our LG Magic Remote had been dropped and the red light was permanently on. The left arrow button on the remote had imperceptibly stuck down.
Using a flat screwdriver I gently prized the remote control apart. With it partly disassembled I was able to check functionality was okay, blow out any debris and operate all the keys.
After reassembling it, the remote control seems to be working perfectly okay and is back to normal.
Indice 6
3 commentaires:
Did the same thing, and it works now.
par
Amazing it worked hopefully it sticks thanks
par
Cool, awesome that worked perfect..🙂
par
I had the same problem, my LG magic remote won’t function properly and once the batteries are placed on the remote, the POWER button would flash 3 times, then if you press any other random button, the POWER button would remain lit (red) indefinitely and will only switch off when a button is pressed but go back to being on afterwards. We browsed the net for solutions from those who had the same problem and tried a lot of things like the pairing by pressing the HOME and RETURN button simultaneously for 5 seconds but it didn’t work. Then I tried the pressing of each button for 3 seconds while the battery is removed, and nothing happened. So we kinda gave up and figured we would let it rest without the batteries for a few hours, and just watch on the tv using the remote app downloaded in my phone. After a few hours of detaching the batteries from the remote, we assembled it again and surprisingly it worked. I am not entirely sure if the resting period or the other stuff we did to the remote was the fixing factor.
Indice 4
4 commentaires:
I also have this problem
par
The same here.
par
Same here 😞
par
Thank you so much! This fixed my problem and remote is working perfectly again! 💖
par
I have not been able to find a sure fix,
Hold home and back button for up 10 seconds this unpairs the remote, then click the button under the number nine it will then ask you to click the track ball to register remote. May have to do a couple a times. Hope this helps. I spoke to a service technician recently, he tought it may be the computer board? If it doesn't work continue the process.
Indice 3
I fixed a similar (potentially the same) problem after much Googling and frustration. See if this helps. Looking very closely at the buttons on the remote control, one button had become very slightly depressed (hardly noticeable to the naked eye), just through a bit of friction / pressure. This means the button was permanently activated, meaning no other buttons would work. As soon as I flicked the depressed button, it popped up to its normal height (<1mm difference) and, voila! Problem solved. If you can't immediately see a button that's slightly depressed you could try flicking each and every button on the remote control. Good luck!
Indice 3
1 commentaire:
Thanks Suzanne! 👍 The power button on my LG magic remote was permanently lit & when I pressed any other button, the TV switched off. 😡 I carefully flicked up the button with a compass point....& hey presto.... back to normal! 🤗
par
this issue happened to me, the remote control was water logged from a water spill
Indice 0
Hi
Or if these things are working and I can’t watch any tv?
Indice 0
I have the same issue. Whenever i put the batteries in, the power light used to blink thrice and after pressing any other button, it stays on. For troubleshooting, I pressed all the buttons and when i pressed the faulty one, the power light didn't blink. In my case it was the scroll wheel button that got stuck.
I have opened my remote and using a screwdriver gently loosened it. After that it started to work.
Indice 0
I had the same issue, the POWER button would flash 3 times, then if you pressed any other random button, the POWER button would remain lit (red) for one minute, and after this the control shut down.
the problem was the circuit was rusty, I cleaned and soldered it, and after this, the control worked normally.
So when the POWER button flashes 3 times is because you have some issue with any button
Indice 0
1 commentaire:
Hi, my 42" LG Smart TV has sound but no picture.
Has anyone had the similar problem and what was done to fix ?
Thank you.
par
My remote light is not indicating that it’s working and on the TV with the power light is on. It’s blinking a green. What is the issue?
Indice 0
my lg power light stay on but want come on
Indice 0
Ajouter une réponse
Steve Kremer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 59
30 derniers jours : 270
Total : 64,856
