Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony Xperia Z3 Dual also known as Sony Xperia Z3 D6633 is announced in September, 2014. It features 146 x 72 x 7.3 mm (5.75 x 2.83 x 0.29 in) body, IP68 certified, 5.2 inch display and 20.7Mp rear camera.
What is the best thing to clean phones?
Hello friends, I want to know what is the best thing to clean the phone, in the past I used warm water then I started using vinegar then ethyl alcohol but I do not really know what is the best thing to clean the phones, I mean cleaning is cleaning the phone from outside like the screen, headphone jack and micro usb port, and from inside like logic board ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
U shouldnt really be cleaning the inside of ur phone with anything unless there is reason to do so like water damage/corrosion
If u do need to clean there are various PCB cleaning solutions available check the country ur in for what everyone else uses I.e lots of people recommend Branson ec liquid in the US for ultrasonic cleaning we dont have that here so we use an equivalent that is mixed with water the important part is to dry it thoroughly afterwards
To clean the screen u can use some isopropyl on a cloth or even window cleaner spray I like astonish lol however spray it on the cloth not on the phone be careful with too many chemicals things like alcohol do get under the screen if it's not fully sealed and will damage the backlight area.
Charging port toothbrush with a bit of isopropyl and headphone port a cotton bud with some of its cotton picked off dipped in alcohol.
Theres probably better methods for all of this I just make sure I get whatever I need on the part I'm trying to clean and no where else…
Indice 1
2 commentaires:
Thank you for this valuable information, I just need to know Where can I find Isopropyl Alcohol ?
par
Its 99% pure alcohol so it evaporates quickly but it has less contaminants which helps clean the item without introducing more gunk
We get it from Ebay lol u could try chemists or electronic hobby shops etc in ur area make sure it's a high purity level as u can get though
par
Ajouter une réponse
Amr Ateef sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 385
