Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why is my cruise control works only sometimes and sometimes shut down
I checked all the fuses but I still can't find the problem
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
On the 2013 the cruise control works great for days when it wants to. And sometimes you can push thr button a 100 times before it works and other times it wont work at all
par
Ajouter un commentaire
1 Réponse
This is usually caused by the cruise control brake switch. Where safe but with car on the road with cruise dropping out, can you set cruise and keep it running by lifting the brake pedal up towards you? If so, then look at the brake pedal switch and locate and adjust the position of the switch slightly so that it does not disengage prematurely.
Indice 0
4 commentaires:
I have check that switch over and over I cant find anything wrong with it. Thanks
par
When cruise is set it doesnt ever disengage
par
Guess you have know more answers. Thank
par
I had a mechanic check my car once for abs problems and apparently that made the cruise work more often but it still does have some problems so i think the problem is connected to brakes but not in the pedal, somewhere else
par
Ajouter une réponse
Damanjeet Singh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 34
Total : 5,032
