pigterrio okay so let’s clarify:
UD : The Sud error code is used to indicate there are too many suds for the washer to remove. This is often caused by too much detergent being used or non HE detergent being used in an HE machine.
After 4 minute the SUD will be displayed and 4 minutes later the F02 will be displayed
Check the drain hose and make sure the hose is not plugged or kinked
Press pause/cancel twice to clear the display
Run the machine through a Rinse/Spin cold water cycle then a Normal cycle without adding any additional soap.
F35 = ANALOG PRESSURE SENSOR FAILURE This failure is displayed if the analog pressure switch has a calibration error. The "F35" error code is indicating a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch.
Check if pressure hose is fixed correctly.
Check if the Air trap/Air dome is not blocked.
Check if the hose is not blocked.
You told us that you did replace the pressure switch but not if you replaced the tube or at least checked it. Let us know what you find.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
