Aller au contenu principal
Repair and disassembly guides for Sony DVD players.
65 questions Voir tout
Dvd only shows in black and white.
Movie is in black and white.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
It sounds like the cables from your DVD player to the back of your tv are improperly plugged in. Try reseating the connections, or change where they are plugged into. Component or RCA Cables must match the colored plugs on the cable ends to the color coded jacks on your home theatre and TV
Indice 1
4 commentaires:
There is no yellow place in the back of the t v
par
Only green a d blue
par
Yellow = video
Red & white = stereo audio
Yellow goes into the green jack if you only have a green port on the back of the tv
par
i tried doing the same thing, but it already has a yellow port, and there’s two red ports but it makes a buzzing noise when i unplug it
par
Fix 1: If your TV has a shared component video (3 RCA) and composite video (1 RCA) input, you need to make sure the colored plugs on the cable ends match the same color-coded jacks on the TV.
Fix 2: For S-Video cables, unplug the S-video cables on both ends and check if there are any bent or missing pins.
Fix 3: Make sure you’re not playing an NTSC DVD on a PAL player or vice versa.
Fix 4: Convert DVD disc to digital videos like MP4, then you can copy to USB flash drive and watch it on HDTV via USB.
Indice 0
Ajouter une réponse
cchail5144 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 5,469
