Sounds like a sick volkswagon stuters with loss of power
98 ford ranger 265834 miles 2.5 4cyl. 5spd manual trans Sounds like a sick volkswagon. Stutters and putters. Losses power especially between shifts. One minute its running great next its not. The catalytic converter was glowing red and because of this I removed it and have straight pipe to the muffler no exhaust leaks and the sick Volkswagen sound sounds like it's coming from the air intake not back at the muffler rural area emissions is not required after removing the catalytic converter a lot of power no longer stalls at lights/ intersection. Ive ran Sea foam thru gas tank and crank case and intake that help restore power aswell. Starts right up hot or cold but you don't know what you're going to get until you go to take off stutter or normal and it seems to have a harder time taking off in reverse I've checked for exhaust leaks vacuum leaks it's not overheating the check engine light was on when I bought this truck 5 years ago remained on all these years up until about 2 weeks ago and that's when these problems started this truck has not given me any problems it's a Workhorse properly maintained. Fuel pump and fuel filter work changed about a year ago and the slave plate was replaced about 2 years ago spark plugs are about a year old oil about three months so what do you think you could be I appreciate your help please.
2 commentaires
Hey Robert. Have you inspected your spark plugs? Wonder if their condition might tell you anything helpful. I wouldn't be surprised if one or more were gas fouled. Sounds like you might be running on just 2 or 3 cylinders. Lots of possibilities that might be causing your issues, and this is a simple check that might point you in the right direction. Keep us posted.
par Tony
One more thing - On the "sounds like a volkswagon" thing, could a leak at the exhaust manifold account for this?
par Tony
