No service after screen replacement
Got given a P20 Pro to replace the LCD as it was not working, and was completely smashed on the back.
Replaced the screen, all starts fine, WiFi works but says no service.
Antenna is secured to the frame properly.
Coax cables are snapped in firmly and are not mixed up.
Tried resetting network settings
Cleared Cache
Performed factory reset.
Any other ideas?
Thanks
10 commentaires
Also noticed it gets signal when it's charging?
par Duane
did you manage to fix this Duane, i have the same issue? signal but only when on charge
par jayb_1991
Did you solve it? I have the exact same problem.
If I charge it, the network comes back.
par nardellaluigi
has anyone came across this issue and got it solve?
I'm facing the same issue
par Moe X
I have the same issue after change screen, no service , I have change antenna main board S but still the problem exists
par Jim
Voir 5 commentaires en plus
