Aller au contenu principal
Sorti en juin 2017, l'iPad Pro 10,5" remplace l'iPad Pro 9,7"
Questions au sujet de 134 Voir tout
Backlight and touch working but no image
Well maybe you can help me.
The display on my iPad Pro 10.5” stays black even though the backlight is on. Sadly it is not displaying anything. The weird thing is that the backlight as well as the touch are still working (tested it with voice over).
I already tried disconnecting and reconnecting the display cables. Do any of you have an idea how to fix this?
Restore in iTunes didn‘t help either.
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @michael_r96
The only thing I can think of is some type of LCD failure or graphics issue with the logic board. If you have already removed the display to reconnect the cables, then you should order a replacement screen from a trusted source to see if it will fix your issue.
Here is a part I would trust:
https://www.mobilesentrix.com/lcd-assemb...
Best of luck!
Indice 1
4 commentaires:
Hi @michael_r96
The only thing I can think of is either your LCD controller has failed or the GPU on your main logic board has stopped working. If you already have the device open, I would recommend you install a replacement screen assembly from a trusted source and see if that fixes your problem.
Best of luck!
par
Thanks, I’ll give it a try
par
Well I replaced the screen and since then it’s working like a charm. Looks like something on the LCD Board itself was broken
par
I've had this exact problem with now 5 premium screens from mobile sentrix and injured gadgets. Either works for a week and goes out or doesn't work at all.
par
Réponse la plus utile
did this happen after a screen repair
Indice 1
4 commentaires:
no it didn’t
par
I just can‘t wrap my head around it. I did not replace the display or anything yet only the backlight and touch is working
par
how do you know the touch is working if you do not have any display
par
Voice Over. It’ll tell you if you touched something
par
Ajouter une réponse
Michael Ritz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 38
Total : 2,306
