Charging issue after screen replacement - temperature too low
Hey guys,
I did a screen replacement on a Honor 10, repair went fine.
Customer returned today and mentioned he couldn’t charge the device as it was getting really hot, I tested it and he was right, the top board was getting very hot.
I have opened it up and reconnected everything and now the phone does not get hot, instead I get a message saying the phone temperature is too low.. as a result the phone does not charge, or it doesnt show as charging because when I restart the phone the battery % has increased so it is taking charge.
Any ideas? is there a way to disable this message?
Thanks!
FIXED
So I’ve finally figured out what was causing the charging/loudspeaker/vibrator issues. When you remove the back cover there is a large foil/heat sheet from the top to the bottom, when you peel the foil off the motherboard it leaves little bits behind, some of those little bits got into the connector for the charging port/LS flex which caused the problems. I have cleaned it out and now everything is back working.
par Kbobble
