My ti-84 plus ce turns off on bright white screen?
I cannot find my problem anywhere in the forums
when i turn it off it shows blank bright white screen
My Texas instrument calculator TI-84 plus CE Works excellent except for when you turn it off it goes off on a blank white screen .
when you turn it on it goes on normally however, when it is on you cannot adjust the contrast or the brightness of the screen, you cannot dim it or even make it more brighter .
please take note that all buttons are functioning properly
and I have tried everything
hard reset pressing second delete and back reset button
also trying to reinstall OS didn't work
also try to clear memory several times same thing
remove the battery for more than 10 minutes then put it back same thing
also try the self test the brightness indicator changes values on the screen but still do not dim or brighten
please advise urgent thank you
