Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Kenwood DNX571HD est un autoradio avec écran tactile large de 6,1 pouces, système de navigation AV, Bluetooth, ainsi que radio HD et satellite. Compatible avec les smartphones Android et Apple.
Head unit will not power up.
I have a Kenwood DNX570HD that has been working fine and just stopped working. It will not power up. The red triangle is off when I start my truck however if I push that button it will light up but then goes back out after about 5 minutes.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
11 commentaires
Can you please add pictures or directions of exactly which board it is and how do you remove the strips from the board
par
The daughter boards are no longer made. If anyone is interested in selling their broken units hmu huntspaintingokc@gmail.com
par
In need of a daughter board myself
par
What are you wanting for it?
par
Robert Hunt, sorry just saw you replied here I sent you an email a while back make me an offer. I don’t really know what it is worth without the daughter board working. My email is shaner12@gmail.com.
par
Voir 6 commentaires en plus
Ajouter un commentaire
3 Réponses
Solution retenue
You can actually take out the daughter board and use a heat gun to float the solder. Thats all it is 90% of the time. Just have to have a little patience and skills to take it apart.
Indice 1
3 commentaires:
Correct..unfortunately, kenwood designed this as the farthest thing away from the fan in the whole deck. By chance do you have any idea why a similar model came with touch screen would work in a split screen mode? Half of the screen is fine and half of the screen is grayed out
par
Where is this daughter board?
par
The daughter board is to left just under the disc unit. You have to take the discplayer out and use a heat gun and apply heat to this board. Heat gun works best but don't get it too close. Do this for about 2 minutes and that should be good. Let it sit and don't move it for about 20 minutes. After that the solder should have time to settle. I have done this numerous times and it has worked. Good luck.
par
Have you tried reseting it??
Indice 0
4 commentaires:
Yes, I have tried to reset it multiple times. I have checked both fuses and also checked all connections to make sure nothing is loose or not making a connection.
par
This is all about resetingand doing a hard reset
https://www.youtube.com/watch?v=judksnNu...
par
Thank you for the suggestion. I actually used that exact video to do the reset.
par
My Kenwood DDX9702S I bought off a buddy and no blowed fuse all connectors good just red light blinking
par
Hey bud. I had one of these exact units do the same thing, so i bought one with a broken screen off of ebay fairly cheap. What the problem ended up being is called the "daughter board", which you can purchase from a site called pac parts, they run abou $145.00
Indice 0
1 commentaire:
Pac parts offered one not too long ago. I have a broken unit with bad daughter board if you need it for anything else. aillsauto@msn.
par
Ajouter une réponse
Shane Houghtaling sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 61
Total : 42,061
