My ps3 on and off button is damaged so it is not starting plz help
My ps3’s On and off button is damaged so it is not switching on plz help
What if the whole power button is missing that little thing it's gone the wire broke can I still turn it on how can I
First, make sure you have power to your console. Check that your power cable is plugged into a working outlet, and also into the back of your PS3. There is a Main Power Switch right next to the socket for the power cord on the back of the PS3. Make sure it’s toggled so that the “O” is down and the “I” is up. You should have a SOLID RED light, right near the power button.
You can start your PS3 with the any synced controller by pressing the “PS” button, just below “select” and “start”.
If you have a controller that is not synced, you can use one of the the USB ports on the front of the console (as if you were going to charge the controller) then press the “PS” button on the DualShock controller.
You can turn your PS3 off by holding down the “PS” button on any synced/connected controller for a few seconds. A menu will appear, and turning the console off is one of the options.
Hope this helps!
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 44
Total : 5,731
1 commentaire
which button? front standby button, controller button or the switch at the rear of the console? If you have the slim model, also check the rear of the console to make sure it's plugged in,
par prop man
