Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Not working - 3 blue light on
Hi,
my Dyson v8 is not working. At first I thought it was a battery, but when I press the power button, the 3 blue lights come on (not just one - a weak battery indicator). But the cleaner doesn't work. Anyone know what the problem might be?
Thanks.
Répondre à cette question J'ai le même problème
Indice 3
5 commentaires
Maybe the following would be of use:
https://www.trustedreviews.com/news/dyso...
par
Thanks for your reply but this is not my Dyson problem. My Dyson didn't turn on at all.
par
Did you happen to find any answer for this
par
Almost a year later..I’m having the same exact problem. Did you ever find out what was wrong?
par
Either battery or motor is affected. One trick may be to bone dry the filter for 48hrc and then try before ordering any new parts
par
Ajouter un commentaire
11 Réponses
Réponse la plus utile
It’s the filter, it’s wet and needs drying off, I shoved mine in the dryer for 10 mins and put it back in and it’s fine, the system has a cut off switch that will switch it off with three lights if the filter is messed wjth
Indice 2
1 commentaire:
The filter is wet, it happened to mine and once it dried off it was fine
par
Even though the Dyson vacuum changed the industry by offering the first bagless vacuum, you may find that it sometimes won't turn on. This is because the vacuum machine has a thermal safety system inside it that cuts the power when it begins to overheat.
You have to wait at least one hour for it it to cool down when this happens, as the machine won't turn on until its recognizes it is cool enough to not overheat the motor. The vacuum can overheat because there is not a free flow of suction through the machine due to a blockage somewhere. When the Dyson powers off during operation, you should:
  • remove and examine the foam filter for blockages
  • verify the clear canister is free of blockages
  • check hoses and u-bends to remove blockages
  • clean the foam filter if dirty; you have to wait until the filter dries overnight before using it
  • clean the other filters in the machine, depending on the model, as each is slightly different.
Verify that, after cleaning the filter and reinserting into the machine, all the components fit together correctly before vacuuming. If the bin isn't inserted correctly or you forget to insert the filters, the vacuum will not work correctly and will overheat.
Wash the Filter
Since the mostly likely cause of the machine overheating is blocked or dirty filters, you must remove them and wash them by hand in cold water. To wash the filter in an upright machine:
Step 1
Turn off the machine and unplug it from the wall.
Step 2
Remove the clear dust bin from the machine by depressing the button on the handle that releases it and lift it away from the machine.
Step 3
Detach the top of the bin by pressing the latch on the front of the bin and lift the top back.
Step 4
Reach in to remove the filter. The filter may be flat and round in a plastic case or it may be a cylinder-type filter, depending on the model you have. Some models have both. Remove the foam filter from the plastic cover, if you have that type of filter.
Step 5
Turn on the cold water and let it run from the faucet. Rinse the filter under cold water until all the fine dust is gone. Squeeze the filter gently to massage any dirt and dust from it under the running water. After the water coming from the wrung-out filter is clear, set the filter aside and let it air dry. For models equipped with the round plastic filter cover, rinse the fabric side of the cover in cold water, and then tap it gently to remove excess water and let it air dry. Set the cylinder-type filter horizontally to dry.
Step 6
Remove the second filter, if your machine has one, from the bottom of the machine. Models equipped with a ball device on the bottom have a filter that you can remove by turning the round inset knob counterclockwise to lift the cover from the filter. Lift the filter out and rinse it under cold water, tapping it to remove excess water after it is clean. Let it air dry.
Indice 1
I've tried everyhing that people have suggested so far, but nothing works. Battery is fully charged and attached correctly. Filter is clean, dry and inserted, but when I pull the trigger I hear a squeek, but it never starts working. No flashing lights, only the 3 battery indicator lights come on. Anybody has any ideas?
Indice 1
1 commentaire:
I have exactly the same problem, did you manage to find a solution ?
par
I took it outta the charger, opened the bin all the way, held down the trigger and she came back to life. Kept it held down as i closed bin in stages. Seems to work now… we shall see if it sticks.
Indice 0
I thought it was the filter - but it was not.
I took the battery off the device (3 screws) , then put it back on (did not do anything to it) - and the Dyson went back on.
Indice 0
Eventually I replaced the battery, and all works well. The battery (a replacement) held for 2 yrs. Now I bought an original one - let's see how this goes
Indice 0
My Dyson V8 is fried and shorted. It sparked and had a distinct smoke and burnt smell when i switched on the trigger. I opened it up today and still could not find the cause of the short. The motor windings are good and already taken out from the PCB. I am doubting the Mosfet M13C30 which I accidentally found online in youtube to be common fault for this particular model. I am unable to test it at the moment since it has a varnish coating and will try to remove it with acetone later to test if it is also shorted.
I tried poking on the capacitors and eventually removed a 35V 1500uF but it was good. I also tested the SMD R030 resistor and it showed 0.1-0.2 Ohms on my DMM which I am not sure if it is fine (i think it is probably okay as long as it is not open).
I also tested the 2 main terminals and could not verify that it is shorted. My DMM does not detect a short.
I want to buy a replacement motor assembly but hesitant to do it until i figured the cause of the fault of this simple board. The battery was also tested and found 24-25V output when triggered ON. I will try to clean the board with CRC cleaner and put it back and see if it works.
If it smokes then holy smokes I will buy a new motor assembly in Ali Express (probably taken out from other V8 but genuine).
Indice 0
I took the battery out and reinserted it and it started working again (battery is not genuine)
Indice 0
In addition, I would like to add that mine was also caused by a semi wet filter but even after I changed it to a clean, dried one, it still had the 3 blue lights of death. What fixed it immediately was that I used a hair dryer and blow hot air into the vacuum where the filter fits. Did it for about a minute, still BLOD. Did it for 2 more minutes, and bam! it works as it should. This was on a V10 but should be the same for these...
Read that there's a moister sensor inside the vacuum... time will also dry it of course but a hair dryer is much faster. Hope this helps someone!
Indice 0
Not sure if your issue is the same as mine, but I had the same issue: all lights when pressed, but the motor wouldn't start. The times it did start I had zero issue, it was sucking as well as the first day. I opened it up and noticed the shield on top of the main board was melted on one spot. I believe the culprit was that the negative terminal screw was improperly screwed in. It made contact with the shield, melted under regular use over the 2 years i had it, and at some point started shorting out. I forgot to get a picture before unscrewed the terminal but in my case it was an obvious mfg error, but the vacuum didn't start displaying problems until a month after the warranty expired.
What tipped me off was that I found a piece of metal in the hepa filter. I now know it was a piece of the washer used in the negative terminal
Indice 0
There is an auto cutoff that will stop it from working when the filters are not clean. Not saying it is the filter but we had a similar issue and worked out that it was the filters. We did a good clean and no problems. We still have the vacuum do this and just clean the filters. Then it works fine. There are a few things that need to be cleaned. Videos on YouTube.
Indice 0
Ajouter une réponse
Ben Azizi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 36
7 derniers jours : 209
30 derniers jours : 873
Total : 61,124
