Aller au contenu principal
Annoncé en août 2017, le Galaxy Note8 est le successeur du Galaxy Note7 qui avait dû être rappelé. Le Note8 a été mis en vente en septembre 2017.
150 questions Voir tout
Can I replace the battery with a battery from a galaxy note 9
i recently got a galaxy note 8 as a hand-me down from my dad and i can't stand the battery life
my plan is to replace it with a battery from a galaxy note 9
here are the battery specs:
the dimensions of the original battery are: 88 x 39 x 5 (mm)
and the dimensions of the note 9 battery are: 87.7 mm x 41.5 mm x 6 mm
we are talking about 2.7 millimeters of difference
do you guys think its possible??
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi @matfrags
I love the idea as I know that Samsung batteries tend to be cross compatible.
Your biggest issue unfortunately is that Samsung significantly changed the connector location between those generations so it will be practically impossible to connect the Note 9 battery once it's installed…
My recommendation in this case is to stick to an original quality replacement battery that you know will work so you don't need to open this phone again once it's repaired and working
Hope this helps!
Indice 1
5 commentaires:
I did notice that the connector on the note 8 battery was on the top right corner while on the note 9 it is on the left corner but that should be an easy thing to fix by flipping the battery over
par
While that might make connecting the battery possible, you will need to fold the cable very tightly which will definitely put in a crease. This could wear down and snap over time like a paperclip being bent too many times which could cause all kinds on battery unreliability.
par
well it's worth a try I guess
par
did you get it at last?
par
It's possible if you swapped battery protection circuit of note 8’s battery to note 9 my alcatel pixi 4 6 battery is swapped from 2500 mah to 4230 mah battery from oppo a3s
par
Did any one tried note 9 battery in note 8 ? Does it fit ? Battery connector is not a prob i can change that.
Indice 0
3 commentaires:
A Note 9 battery may fit the connectors, but it is on the other side of the board. If you flipped the battery over to connect it, that would put a crease in the cable, and is therefore not advisable.
par
@leo52700 do you all remember the Note 7? Do you remember why it blew up? Had nothing to do with the battery but everything to do with the phone casing having been to small. 3mm in size may not sound like much but it's enough to cause the same issue. Get the right battery so you don't suffer the same fate.
par
Thanks for the advice
par
Ajouter une réponse
George Fragoulis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 37
Total : 2,590
