Aller au contenu principal
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 questions Voir tout
horizental pink line flicker on the top of screen on low brightness?
while making brightness level to low a pinkish line appers on the top of display and window freezes and shut down but if i increse brightness to high it goes away but after using on full brightness after sometimes suddenly window freezes and shutdown.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
could be the LCD panel or the GPU. Connect an external monitor. If that show a good picture you know it is most likely your LCD panel that needs replacing. If the external monitor is showing the same issues, you have having problems with the GPU on the logic board and will have to at least disassemble your laptop to inspect. Hope this helps, good luck.
Indice 1
Ajouter une réponse
sujan pokharel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 164
