Can not log on or operate
computer screen only shows chrome logo on white screen, when I open thte chromebook, then goes off, no response from touch
Which model?
See this:
Remplacement du SSD du Acer Chromebook C720
Google/look in youtube - most likely it is a loose contact that SDD is disconnected.
Gently unscrew - check everything like loose cables/connections.
Try.
alternately, the SSD is damaged. Buy an replacement.
See Remplacement du SSD du Acer Chromebook C720
Post here again…
Model R 13
N16Q10 will not start, or respond to key strokes or touch screen just white screen with google logo
Please help with suggestions
May be the OS is damaged? Do you have any messages
https://support.google.com/chromebook/an...
Can you put a photo of the screen?
Gently open and clean and check all connections are OK.
no, there is no response from keystrokes or touch
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 61
