Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bienvenue sur la page du projet Réparation rapide ! Le projet Réparation rapide fait partie du programme de rédaction technique universitaire d'iFixit. Ce projet concerne les réparations simples et rapides d'objets du quotidien tels que des vélos, des guitares, des jouets et bien plus encore. Si vous êtes étudiant et que vous souhaitez obtenir plus d'informations sur le projet Réparation rapide, veuillez consulter edu.ifixit.com et cliquer sur le type de projet « Réparation rapide ».
Can anyone tell me how do I use the flex extension?
Can anyone tell me how do I use the flex extension in Ifixit pro tech kit?? It’s not magnetic.
Répondu ! Afficher la réponse J'ai le même problème
Indice 12
1 commentaire
The Flex Extension in the iFixit Pro Tech Toolkit is a bit confusing at first, but it’s simple once you know it.
### How to use it:
* Insert the extension into the driver handle first
* Then attach your bit (screw head) to the front end
* Use it like a flexible shaft for tight spaces
### Important point:
* It is **not magnetic on purpose**
* It holds bits with a **friction fit**, not magnetism
### Tip:
* Push the bit in firmly until it feels locked
* If it feels loose, re-seat it again
It’s designed for reach, not magnet strength.
par Partager
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @kmredul
Push the bit into the hollow end until it is stuck in place. It will need to be pushed a little harder versus putting the bit directly into the driver. If the bit is not magnetic, you can attach a small magnet to the bit or rub the bit itself against a larger magnet.
Indice 15
3 commentaires:
Yeah, I figured it out. BTW thanks for your help.
@refurbpro
par Partager
Man I feel dumb. Thank you.
par Partager
I just received a Mako Precision Bit Set and was unsure about how to use the flex extension and the 1/4" adapter. With the confidence of this instruction I found the flex extension to be extremely easy to use and was bemused as to how I hadn't worked it out myself. The 1/4" adapter needed substantial force to manage to get a bit clicked into place the first time in comparison, although now it is substantially easier to use!
par Partager
The 150mm Flex Extension in the 64 Bit Driver Kit (Mako/Pro Tech Toolkit) does not have a magnet. The slot uses friction to secure the bit, unlike the iFixit Drive Handle which uses a magnet. If you insert a bit and then push it in with additional force it will click into place. To remove the bit, simply pull the bit up and out from the socket and the friction grip inside will release it.
If you're not able to get the extension to hold the bit, please Contact Us with your order number.
Indice 4
Ajouter une réponse
Khaliduzzaman Mredul sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 48
30 derniers jours : 207
Total : 6,854
