High beams will not activate
2005 corolla, High beam will not activate when the switch is placed in the high beam position. The indicator light on the dash does not activate either. When the switch is placed in the temporary high beam position, the headlights and the light on the dash work properly. The low beams work properly. I have replaced the switch on the column, checked all relays and fuses and bulbs, everything is working properly. What should I do next?
Update (10/22/2019)
I have already replaced the dimmer relay. That did not fix the
2 commentaires
The schematic is there for your pleasure, troubleshooting with a volt meter is next, the DRL is looking suspect but the proof is in the voltage measurements my friend.
par Duane Donaldson
I have the same problem. How did you fix it ? If you did.
par Hamish
