Aller au contenu principal
The HTC Desire HD is an Android smartphone by HTC Corporation.
Questions au sujet de 26 Voir tout
What layers and components does the screen consist of?
Edit: This is 11 years later, but I just wanted to thank everyone who helped me in this thread as I never wrote a conclusion.
I ordered a digitiser from eBay which cost ~$20 USD, spent a day disassembling the phone (quadruple-checking every step) and repaired my screen with zero issues!
All up I saved $155 because the quote a repair shop gave me was $175. The phone itself had only cost me $85 on top of a 24m plan so fixing it myself was the only realistic solution. Very grateful to iFixit and a bunch of YouTube videos made at the time.
What are the 'layers' that make up the screen of the phone?
From my lack of understanding, here is what it seems to be:
(Imagine the phone laying face up)
[Towards front of phone]
- Glass panel -
- Digitizer -
- LCD screen -
[Towards back of phone]
I'm guessing that's wrong however. Is there another plastic or glass layer somewhere in there? Is it out of order? Is the glass panel the LCD screen?
Thanks in advance for all your help!
digitiser display panels WVGA TFT touch touchscreen capacitive part component make up makeup make-up layer (this is just here to help with searches)
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Just tag the question. You do not have to add your search strings on the bottom of the question ;-)
par
Thank you @oldturkey03 @dman113 @BurnieG @j3illye22 @teetopp @Simon Pengelly, I edited the question with a decades-after conclusion :)
par
Ajouter un commentaire
8 Réponses
Solution retenue
Not exactly sure what you are looking for, I can only add that your display consist of the LCD and the digitizer. I do know that people refer to this as the "Glass" or the "Touch screen" So in order to replace the display you would need a digitizer and a LCD. Here is a video from HTC that will show you what needs to be done. Shows the repair of a cracked digitizer. The parts needed are available here Hope this helps. Good Luck
Indice 3
9 commentaires:
All right- so the display is made up of just the LCD and the digitiser. That makes sense.
Are both of them made of glass?
Which of them is 'on top' and which is 'under'? For example, if I put my finger on the screen of my phone, am I actually physically touching the screen, or the digitiser?
Thanks for the video links and explaining that!
par
The reason I'm confused is because the outer/upper/external piece of glass on my screen is smashed and cracked.
However, all touch functionality is fine and the display is fine (no distortions, funny colours, no bad pixels, everything displaying just fine).
Therefore, as far as I can see, my LCD screen is okay and my digitiser is okay.
If that's the case, what exactly cracked?
par
Thanks so much! I get it now :)
par
Just like pollytintop clarified, the outer layer is glass adhered to the digitizer. That is the part that will show the cracks. The digitizer is underneath the glass and most often can NOT be separated. It is technically two pieces that make one unit. When the glass breaks your digitizer still works because the circuit is not interrupted.
par
All right, I am replying to both of you, oldturkey and pollytintop in this comment.
I guess that when I was what I'm physically touching, it would mean the glass specifically. That makes sense. Am I right then to say that three layers 'physically' make up the display? (e.g. a wheel is physically the tyre, the rim and the hub.) First the glass, then the digitiser, then the LCD?
However, is it also correct to say that if you were to order a replacement glass, you would need to buy a digitiser? That is, a digitiser that consists of a circuit layer and a glass layer?
par
Voir 4 commentaires en plus
Notes/summary for those who arrive at this page:
- The only glass component of the screen/display is the digitiser - When your screen shows cracks, it is the digitizer that is cracked
- If your screen is cracked, you will most likely only need to replace the digitiser
- Whilst your digitizer may be cracked, it may still have full touch functionality due to the circuitry remaining intact
- This is the layer 'make-up' of the screen/display:
[front of phone]
[DIGITISER / DIGITIZER LAYER]
[LCD PANEL LAYER]
[PHONE INNARDS]
[BACK HOUSING COVER]
[back of phone]
Indice 1
1 commentaire:
Just to clarify... The digitiser is the same size as the LCD and is adhered to the outer glass. When your display is cracked it is the GLASS not the digitiser. When you touch your phone display you touch glass NOT digitiser.
par
http://www.wiselyguide.com/amoled-lcd-be... about half way there's a pic that explains this.
Indice 1
Most touchscreens have more than two layers.
On most touchscreens there are usually two layers that make up just the digitizer. The glass on top that you touch and the actual digitizer sheet which consists of the touch matrix circuitry. The digitizer sheet is adhered to the glass so it often appears to be one piece. So you where correct to assume glass cover, digitizer and then lcd. The digitizer sheet and glass have a small gap that has an adhesive in it. On both the glass(bottom) and digitizer(top) is a transparent metallic conductive coating which is usually indium tin oxide. The human touch is conductive which allows for the electical sensors in the digitizer and glass sheets to sense the touch at a specific location.
Some of the newest technology such as Super AMOLED is able to get away from the two conductive sheets and has the touch sensors built into only one sheet, so these touchscreens would be an exception. So most forms of touchscreens consist of three or more layers.
I'm sure as time goes on the technology will change to allow for thinner touchscreen such as the super amoled.
Indice 0
^ finally someone on the right idea. there's a !&&* of a lot more than 2 layers to a touchscreen. this is a broken 4s screen right here - that's 5 layers in addition to the "glass" that's still glued to the LCD.
Indice 0
1 commentaire:
The Bottom part of your picture is the Back-Light assembly that is under the LCD to light it up so you can see it. Mainly Diffuser sheets...a multi-layer, semi-transparent plastic sheeting to help spread light evenly across the lcd... but not part of the actual LCD assembly
par
==So on my phone the glass has been cracked and and chipping away exposing what's underneath I'm assuming the LCD display. But I'm confused because I can still touch the LCD and it responds to my finger so in theory my phone still works without the glass on it. Can anybody explain that?
Indice 0
1 commentaire:
There are some phones you can do a "Glass only" repair. Where there is a layer of glass (Like the Galaxy s5) over the Digitizer and LCD. Where the Digitizer if fused to the underlining LCD instead of the Glass. I don't know your particular phone so I can't speak with experience on your particular model. I searched for a link for it and found this: https://www.youtube.com/watch?v=5ImE5hUX...
If you are able to remove the entire front glass and it still responds to touch, then your digitizer is fused to the LCD. If there is a ribbon cable attached to the Glass, then your digitizer is fused to the glass :)
par
There's lots of confusion above.
The OP is correct in saying that the cracked glass he has is not the digitiser (which respondes to finger-tips) because that still works. The LED screen (see https://en.wikipedia.org/wiki/AMOLED for example) which creates the image is under the digitiser. Other layers like backlight, adhesive etc can exist and the LED itself is made of at least three layers - depending on what you count as a layer. Whether the layers can be separated or not depends on how its been put together and with what glue.
I'm just picking away at a broken front glass (only) on a Galaxy S7 edge, using acetone to soften the glue fixing it to the digitiser.
Indice 0
As I understood it depends on the phone what is fused with what. I was wondering is it possible to replace just glass/digitizer on Mi Max? I do not know is it fused with LCD.
Indice 0
Ajouter une réponse
Ron Au sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 110
Total : 46,471
