Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La deuxième génération de PlayStation Vita, la série PCH-2000, est communément appelée PS Vita Slim ou PS Vita 2000. Annoncée au Japon à l'automne 2013 et sortie en Amérique du Nord en mai 2014. Il s'agit d'un appareil de divertissement portable. Prise en charge par : Wi-Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Numéro de modèle : PCH-2001.
Is my motherboard dead?
Hi all,
I would like to ask if anyone had a problem with PS Vita 2000 like I do. The console does not turn on, at all. It is charging (solid orange light) but does not react when I press the power button.
I already checked the most common problems and tried those steps:
  • Replaced battery with a known good one.
  • Pressed PS, R and Power button combination.
  • Tried charging it with different charger and power cord.
  • Looked for signs of water damage (didn’t found any).
  • Checked continuity on fuses around the power section (all working).
  • Placed the MB in another unit with working components (power button, controller boards, and battery).
Can anyone give me some advice on how to troubleshoot this one?
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
2 commentaires
Hi, I'm trying to find the fuses on mine since my backlight is not working. Do you have the schematics? Or a picture highlighting their location?
par
@ed Martinez you posted your request on a 3 year old question that is no longer being viewed. Your chance of getting a valuable answer which hopefully helps you with fixing your system, are greater if you create a new question. Give as much detail as possible and add some pictures of your board. https://www.ifixit.com/Answers/Ask
par
Ajouter un commentaire
2 Réponses
Solution retenue
I managed to revive it. If anyone in the future will look for the answer, here is it:
Take your hot air station, a lot of flux (higher quality will be better) and reflow those two chips at around 320 - 350 Celsius degrees.
Indice 2
2 commentaires:
Still in the 2024 , you helped me and my ps vita is functioning again! thanks mate!
par
how long do you reflow them at that temperature? thanks!
par
Inglés
! My console is back to life! After three years without using it, when I wanted to turn it on nothing happened. I have spent 4 months trying everything, key combinations, change the battery, the charger and the usb cable, but without any results.
As a last attempt Dismantle the complete motherboard, clean everything with a cloth with Isopropyl Alcohol and a toothbrush, dry it with a hair dryer, mount everything again and when you connect it ... Like new.
Apparently the problem was the rusty motherboard.
Indice 0
Ajouter une réponse
Adam Toda sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 94
Total : 5,176
