Aller au contenu principal
Sortie en juin 2016, s'identifie au numéro de modèle A3003 en Europe et A3000 en Chine et en Amérique du Nord. (Source : https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
20 questions Voir tout
Power and volume buttons sunk inside the body of Oneplus 3
So, the power and volume buttons on my OnePlus 3 started feeling a little weird lately and slowly one by one all just kind of sunk inside the body of the phone and stopped working altogether. So, I opened the phone and found that the actual internal buttons were fine and working, but the rubber thingy that pushes those buttons from outside and worn out and was unusable. So, does anyone know if those rubber thingys can be replaced or is there any diy hack to make them work or do I need to get the whole back cover replaced?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
The same thing happened to my notepad..what do I do?
par
Ajouter un commentaire
2 Réponses
The same thing happened to me a few months ago. The power button went first, and then the bottom volume button some weeks later. I changed my phone battery today and discovered the little plastic bits had basically degraded and crumbled. So now even though my phone is charged up, I can’t get it to turn on and I haven’t seen anything on any forums about what to do about this specific problem. You posted this since 2019, have you had any luck since then? Buying a new phone is not an option for me.
Indice 0
1 commentaire:
Well, sorry for the late reply. Unfortunately, my Oneplus broke completely before I could get it fixed. The only way to fix this is to replace the complete back housing. So, if you could get a after-market housing, that's the only way to get the phone working properly
par
There is an inherent fault on the case buttons of the OP3/3T. The Rubber plungers that make contact with the internal ribbon cable button fails over time, it goes hard and brittle, then crumbles. The case buttons need replacing. To do this you require to remove the back case (follow the instructions). Running down either side of the case is a granular adhesive strip. Using tweezers, peel this back carefully until you go past the case buttons. You will see a tiny metal spring clip that tensions the case button in place. Using tweezers again, gently lift that off. You can then push the button from the inside and it will fall out. Then replace with a new button in reverse order.
Indice 0
Ajouter une réponse
Vandan Bhardwaj sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 34
Total : 703
