How to replace door
Hello,
I have a Kenmore microwave model number 401.88522011 made by Samsung and the plastic around the door cracked and a piece broke off, so I ordered a new door part number DE94-02053B. It came with no instructions and I can't figure out how to get the old door off. It's not a usual door, it opens from both the left and right sides and there are no screws holding it in. If anyone could tell me how to remove and install the door or direct me to the service manual, it would be greatly appreciated.
Typically these have a top access panel above the door. Do you see some screws above the door which you can use to access the door hardware?
par drmdolfan
Thank you for your response, I did remove the access panel and the was no screws or access to the pins. This door can open both to the left and the right sides. There are two pins on each side which catches on to the hinges which are inside the door assembly.
par Rick Epstein
Did you figure it out? We are in the same boat.
par Lisa Smith
