Aller au contenu principal
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
23 questions Voir tout
Cleaning the boiler outlet
I can’t get the screw out to clean the boiler outlet. It seems to be welded in. Water won’t pump through. Do I have to throw the whole machine away because the screw won’t come out?
Update (01/08/2020)
Here are the pictures of the screw I can’t get out and the boiler holder (holds the coffee filter).
Répondre à cette question J'ai le même problème
Indice 2
2 commentaires
jwsacco post some good pictures of what you are up against. That way we can see what you see and hopefully help you out.Ajout d'images à une question existante
par
I can't get the screw out. It's stuck fast. I have tried WD40. Any advice would be appreciated.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
jwsacco it is not welded in. I think it is just hard to get a good grip on it. Use a phillips head socket and a ratchet. Place the socket into the screwhead and use a small hammer to tap the bottom of the socket thus loosening the screw a bit. The use the ratchet on the socket to remove the screw.
Check the first 45 sec off this video
Indice 1
Ajouter une réponse
jwsacco sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 37
Total : 2,086
