Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
20 questions Voir tout
6 red blinks and nothing
Hello,
I have five years old Sony Bravia KDL-40W600B. Two months ago my TV broke down with the 6 blinks symptom. I browsed the internet for some solution and finally ordered via eBay Sony A-1983-521-A LD Board and replaced it. Everything was fine until yesterday when my TV broke down again with the 6 blinks symptom. Please advise me what to do?
Thank you in advance,
Vadim
Update (01/21/2020)
There is one very interesting thing. When I bought a replacement board the back side of it was green all around. Now I see it's discolored under one of capacitor like on old board. Maybe this fact can help to trace up an issue.
Thanks,
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@loravadim this could have been caused by a lesser quality replacement board. There is always a possibility that your LED backlights are causing this but at this time I would go ahead and replace it once more . I’d consider a different source for that board. Let us know if the new board resolved this issues.
Indice 1
15 commentaires:
Thanks,
par
@loravadim it is one of the IC's that overheated. If you can get a couple clearer picture we might identify the type and model of it and determine if this is a common failure. It is possible that this is one of those boards that is "meant" to fail after a while by using substandard parts.
par
@loravadim identified the IC as a BD9397EFV LED driver. Yours obviously failed and possibly because of an overvoltage
par
Thank you. What is a possible solution? What do I need to replace? Thank you again.
par
A replacement board is less expensive than to get it repaired. I wonder if your board just gets to many power spikes. You may consider a surge protector and give that a try. Again, it may just have been a substandard board.
par
Voir 10 commentaires en plus
Ajouter une réponse
Lora Fomina sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 1,350
