Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations relatives à la réparation et au démontage de la souris sans fil ergonomique MX Vertical de Logitech. Commercialisée en 2018, elle porte le numéro de modèle M-R0074.
MX Vertical Optical Repair
Hi there, my MX Vertical isn’t moving the cursor anymore.. However, the buttons still work (e.g., left/right click, wheel, fwd/back, etc.). Does anyone know of a way to repair this?
Is the optical sensor easy to replace? Could this perhaps just come loose?
Any experience with this issue would be greatly appreciated as I haven’t seen anything pertaining to this particular mouse.
TIA
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Wow, thank god for the internet. This was super easy to fix once I found my super tiny electronics screwdriver. I dropped my mouse super hard and thought it was done for. So glad that this $70 mouse was salvaged from the landfill by some quick googling and helpful photos. Thank you so much!
par
Ajouter un commentaire
7 Réponses
Solution retenue
So I figured it out. Thanks to that video provided by @justicegoat I was reassured that this device could be opened safely without breaking it, i.e., no glue.
I opened it up and noticed that the sensor was just loose and was no longer pointing to where it should be. Unfortunately the anti-stick strips couldn't be salvaged.
It was easy to clip it back in place. I had dropped this mouse from my desk enough that it must've dislodged from its clipped home. Oops.
Great mouse, though.
See images.
Indice 22
14 commentaires:
Thank you, thank you. Even I, a 64 year old grandma with limited tech experience, was able to fix my mouse. Thank you!
par
you save my mouse, thank you !
par
100% - -Just saved me getting a new one - was sensor that had moved after dropping it -- Thank you sir :)
par
Thanks a lot, Sir! You're a saver.
par
This worked for me too. Thanks for your help!
par
Voir 9 commentaires en plus
Found this video, it’s in Vietnamese but it helped me open the mouse and fix that cursor issue.
turns out the lens connector was loose
Good luck!
https://www.youtube.com/watch?v=09ffN9M6...
Indice 6
I followed @l3fl3r instructions. Thanks!
Also, by being careful, I managed to remove the anti-stick strips/skate/feet and put them back after.
Indice 2
you can find replacement scates on aliexpress, search for ..2 Set Mouse Feet Glide Sticker Curve Edge Skates For-Logitech MX Vertical/MX Anywhere 3 Mouse M04 21 Dropshipping
Indice 1
I don’t think you can replace the optical sensor since most mouses have it soldered on the mainboard.
Indice 0
1 commentaire:
No, you're correct. When I contacted Logitech, to order the anti-stick pads I ruined, they only offered to replaced my mouse. So spare parts are not going to be available. But In my case, the issue was the sensor and since it was an easy fix, I can still use it. But without the pads, it's not great for anything requiring any high dpi. It'll be a donor mouse should I run into any issues with my replacement.
par
Thank you for the useful information.
Also, I was able to save the anti-stick strips by using a heat-gun to revove them and then to re-attatch them. I heated up the strips so that the glue turned softer and allowed me to remove the strips easily. When I was ready to re-assemble, I heated up the strips again so that the glue became sticky again and then just put them back on the mouse.
Indice 0
There is no need to replace or remove the anti-stick strips! You can simply locate the screws by sliding your nails along the strip and feeling for the holes. Once you find a hole, simply use the screwdriver to pierce through. This way, the strip remains intact ;)
Indice 0
Ajouter une réponse
David Lefler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 37
30 derniers jours : 192
Total : 13,853
