step hard on the gas, there is a very noticeable event in the accelera
Manual Tranny, 2013 Honda Civic, basic engine, 12555km, no check engine light. SAME PROBLEM: if I step hard on the gas, there is a very noticeable event in the acceleration. You can describe it as a dip/drop/hesitation/stall/pause in the acceleration; but it is only like a bump that you roll over and then it is normal again. It is most noticeable in second gear but I am convinced it could happen in all the gears; seems to be noticeable only when you are accelerating with high torque. If I accelerate modestly and smoothly, there is no hiccup, no event; just smooth, predictable acceleration. So it is NOT a problem related to automatic transmissions. Because it seems to be related to engine load, I am leaning towards air leaks, air filter, engine oil; then move on to spark plug leads, O2 sensor, tranny oil.
You say this "event" is noticeable in second gear. Does it occur in any gears after second like 3rd, 4th, or 5th? And can you be a bit more descriptive of this "event?" When you step on the gas does the RPMs go up really quick but no acceleration?
par Jesse Hooton
