Marshal Major II bluetooth battery is not charging
Recently the battery stopped charging ( no red indicator ) everything else is still working fine, but no charge. No red led, no dim white. One weird detail is that when I try to charge the headphone with bluetooth on, it shut down immediately ( some sort of power protection ? )
Here are the things i checked:
- USB connector: I connected to 5v and measured 5V on the PCB => seems fine
- fuse : I measured a very low resistance => seems fine
- battery : i unsoldered and charged it with a separate Li-ion charger ( seems ok ). I then measured potentials and found ( GND:0V, NTC:0V, VCC:3.7(ish)V ). I also measured resistance between GNC and NTC and found around 10kohm.
I think the problem comes from NTC, but I’m not sure to understand who this works:
- Am I supposed to measure 0.5*Vcc on NTC when the battery is disconnected ? And does it change when the battery is connected or charging ?
- if NTC was malfunctioning, shouldn’t i measure a resistance of 0ohms of infinite resistance ?
Thanks !
hi! any luck with charging malfunction?
i have MID with the same issue...
i think power controller is dead
par Ba Arg
