Dryer won't turn off.
The setting dial keeps going around without stopping. I replaced the timer switch already. The dryer heats as normal. The dryer will only shut off if I open the door or unplug it. It goes through all the settings.
Indice
0
@astro19 what is your dryers complete model number?
par oldturkey03
It's a 70 series. #97374210
par Astro
Hi @astro19 ,
Does the dryer start straight away when you plug in the power?
par jayeff
Yes. Also as soon as I shut the door.
par Astro
Hi @astro19 ,
Have you checked that the start switch is OK and not permanently operated?
Disconnect the power and use an Ohmmeter to check if it is OK or short circuit perhaps
par jayeff
