Aller au contenu principal
La manette HTC Vive peut être identifiée par son numéro de modèle : 2PR7100. Il s'agit d'une manette de mouvement de première génération lancée par HTC le 5 avril 2016 en tant qu'accessoire faisant partie de l'ensemble de réalité virtuelle Vive.
Questions au sujet de 17 Voir tout
Is there any way I could buy a replacement track pad?
Okay so, I found out specifically that on one of my controllers the haptic feedback and sound is not working. The reason why is because there is a thin ribbon cable that tends to brake inside the controller, as seen here that causes the feedback and sound to not work. I was wondering if anyone knows where I could purchase a replacement trackpad. Please and Thank you.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
The only thing I have found is on ebay, there currently is this listing up for bids and a listing for a lot of 5 that don't click. should be able to harvest the touchpad or repair one.
https://www.ebay.com/itm/HTC-Vive-Contro...
https://www.ebay.com/itm/LOT-OF-5-DEFECT...
par
Ajouter un commentaire
1 Réponse
Also apparently the steam controller uses a near identical track pad if you can buy a donor steam controller cheaper then a donor vive wand give that a try.
Indice 0
1 commentaire:
Unfortunately the trackpad in the controller has a plastic assembly welded to it to turn it into a moveable button so a steam controller would not work.
par
Ajouter une réponse
Jake Gardner sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 420
