Hi @michael_1213
Is there power available at the fan i.e. can you turn on the light/fan manually etc?
Here’s the instructions on how to set up the dip switches to enable the remote to work with the fan’s controller receiver board.
(click on image to enlarge for better viewing)
If you can’t get it to work when trying any of the 16 possible combinations, then either the remote is faulty or the receiver board for the fan is faulty.
Does the receiver board look OK i.e. not burnt or distorted?
If not, then the option is to get either a new remote control - supplier example only or a new receiver board for the fan.
Here’s an image that may help with installing the new receiver board, maybe.
You may have to check the model number of the receiver board and then try to find a replacement by searching online for Hampton Bay (insert receiver board model number) receiver board, to find suppliers of a suitable replacement. There should be an installation guide with the replacement board
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
2 commentaires
Hi,
What is the make and model number of the fan, also the model number of the remote control if it has one?
Have you checked that the batteries in the remote are OK or tried new ones, you didn't say?
par jayeff
Hampton Bay made both fan and remote. "Fan HD" is the only reference I can find on either unit. Battery? First thing I checked when it stopped working; it's good.
Thank you for the reply.
@jayeff
par Michael Berry
