Aller au contenu principal
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Starter wont disengage, why
I have replaced the starter on my 2000 chevy cavalier with 2.2L engine 2 times in 3 days, it works great at first but will not disengage, there is nothing wrong with the flywheel, not sure how to fix it or what to check.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
I figured out the problem, the person that put the first replacement on had a wire in the wrong spot. Thanks for the help
par
Ajouter un commentaire
1 Réponse
Solution retenue
Check the spacer in the nose end of the stater. If it is missing the bendix gear will extend to far into the flywheel causing it to hang in the engaged position.
Indice 1
1 commentaire:
When I put the starter on it did have the little sleeve but when I took it back off not even a day later it was chewed up
par
Ajouter une réponse
Jwanna C sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 163
