Aller au contenu principal
Comment réparer la PlayStation 4, console de jeux télévisés produite par Sony Computer Entertainements, également connue sous le nom de PS4. Annoncée le 20 février 2013 et lancée sur le marché le 15 novembre 2013.
20 questions Voir tout
HDMI PIN 18 issue
Hello everyone,
I bought PS4 with faulty HDMI port to fix it, learn something and get some practise. I am now waiting for my new HDMI port, but I have noticed something on the bord. As I checked conductivity between PADs and points from the diagram, I found, that PIN 18 is not connected to the capacitor on the right side(18).
I have also noticed that the back side of the diode and capacitor(Yellow dots) are connected and both shorted to ground.( Front side of the diode and capacitor Is connected too, but not shorted to ground.) Is that right ? I dont have another board to compare with. And if yes, where does PIN 18 go? Could that be an Encoder IC fault?
Répondre à cette question J'ai le même problème
Indice 5
3 commentaires
@marcinn ..please list which board you have for further diagnostics help
par
Where can I get that? Theres SAB-001 on motherboard, Is that it?
par
Ajouter un commentaire
8 Réponses
Réponse la plus utile
martin … for sab-001 follow this pinout.
https://www.youtube.com/watch?v=KTQ5JkaL...
skip to the end for the testing points. if it doesnt match, theres a fault. post back for further assistance.
Indice 1
10 commentaires:
Yes, the PIN doesnt match the video
par
youll want to remove the component that doesnt match and test out of circuit. if it tests good, place it back and continue. something is shorted. it could very well be the hdmi contoller. i would start there and recheck the pinouts.
par
Okay, I am gonna try that, thank you
par
@jostewcrew so I have desoldered the diode and capacitor and noticed, that I have 3 pins on the HDMI controller (firts 3 from the left side behind the HDMI filters) shorted together. Dont you know where they should connect ? And when I removed the components, the pin Now connect to the right place
par
Sorry, not only First 3, also some that Are connected to HDMI filters are shorted with first 3 pins
par
Voir 5 commentaires en plus
Hi, I have the same problem, maybe someone could give us feedback about value of this cap and diode from working MB. For me its 1,5 Ohms from the left side of thie components.
Thank you!
Indice 0
14 pin point root i want
Indice 0
i need help!!!!!!!!!
Indice 0
i need help!!!!!!!! andrew!!!!!!!
Indice 0
how to get sab-001 ps4 hdmi disgram motherboard!!!!!!!!
Indice 0
Capacitor and the diode are both grounded (caps negative if polarized diodes non-striped side)
Capacitor is noise filter
Diode is a protection for polarity
Both are for local part of circuit
Indice 0
Hey friend, do you happen to know which ceramic capacitor is the one next to the zener diode?
Indice 0
Ajouter une réponse
Martin Jančík sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 115
Total : 11,263
