Why laptop only turn on when l remove the LCD cable from M connector
My laptop only turn on when l remove the LCD connector from motherboard and it display to the second monitor nicely. What can be the problem?
If you are positive that the connector is connect correctly then you have a defective laptop screen which is shorting out the entire sytem so scrren must be replaced as so:
https://www.youtube.com/watch?v=MbkFwlrH...
or
https://support.lenovo.com/nz/en/solutio...
Make sure that the connector is attached firmly to the system board when installing.
The other possiblity is the BIOS needs to be reset but disconnecting the CMOS battery:
https://support.lenovo.com/us/en/videos/...
This is unlikely though as it works fine with the internal screen disconnected and connected to external monitor. But hey worth a try.
The hardware maintenance manual might help:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 281
7 commentaires
Elton are you saying that when you plug in the cable from the second monitor, your laptop screen stops working?
par Malcolm Wickham
No l am saying, when l plug the laptop LCD screen on the motherboard ( that's the built in screen) the laptop won't turn on, no power lights nothing.It will do like a dead laptop,but when l remove the LCD cable(rebbon) on the motherboard,the laptop turn on and l use my HDMI cable to display to the external Monitor.
par Elton Makombe
@ellomax
Hi Elton,
You haven't commented on the answer yet?
Mike
par mike
Thank you Mike l will try to buy a new LCD screen becourse l insert the LCD connector for many times but nothing is working.
par Elton Makombe
@ellomax
Looks a fairly straight forward job so I expect you will have success. Let us all know how it goes.
It is always nice when there is a service manual easily available as a pdf on the web. Good points to Lenovo.
par mike
Voir 2 commentaires en plus
