Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La montre connectée quatrième génération d'Apple, avec connexion aux réseaux mobiles en option, mise sur le marché le 21 septembre 2018.
Did a screen replacement and now I have no WiFi and very bad Bluetooth
So as the title says, I performed a screen replacement on my watch (S4 44mm) and it works but now my WiFi never shows any networks and the Bluetooth connection is extremely poor (watch will disconnect if I have phone in my pocket and watch on wrist on table, it’s that bad).
i was looking around inside and comparing with the tear down to see what I could have damaged or forgotten to put back, and the only thing I noticed that was missing was this:
Then I remembered that when removing the display, that little gold thing popped off and flew across the room so who knows where it is now. Anything I could use to replace it? Since I’m pretty sure that connects with a little metal tab on the screen to provide wireless functions
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Solution retenue
Okay, I slept upon this for a couple days, then I decided to solder a tiny wire to the antenna contact on the screen, then tin the end of the wire and stick it in the little hole where it goes on the left side of the Taptic Engine with the crown facing on top right. If done correctly, this wire will serve the same purpose as that little gold thing that popped off. As for corrosion in the future, I have no idea what’ll happen or if it’ll happen at all.
Indice 0
how is your watch now? as i did a screen replacement at a shop and i'm facing the same issues
Indice 0
1 commentaire:
Ended up selling it to a friend. No complaints from them, the wire is probably still soldered in there
par
Ajouter une réponse
ThatStella7922 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 32
Total : 692
