Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Modèle A1001 ou A1025 / processeur G4 à 667, 800, 867 MHz ou 1,0 GHz
Problems connecting with 802.11b Airport card?
In the interest of extending the life of my PowerBook G4, I installed an 802.11b airport card. My issue has been accessing the existing wireless network, which is NetGear 54Mps 802.11b/g. It won’t see the network, and when I tell the preferences what network I am looking for it doesn’t go through. I figure the problem lies with the differences of the protocols. Does anyone have any insight into this issue?
Thank you for your help
Richard
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Your problem may lie in the security protocol of the network. What Encryption type are you using? WEP? WPA? WPA2 Personal? Another thing, if your router has this option, make sure your router is set to "compatibility" or "legacy" mode, and not set to see just wireless G.
Indice 2
2 commentaires:
I ended up setting the router to WEP 64 bit Hex. Took one of the generated passwords, plugged it in to the laptop and that worked. After running around and resetting all of the other machines and phones in the house everything worked out fine. Thank you for your help and advise.
Richard
par
No problem, glad I was able to help.
par
Ajouter une réponse
rpeal38 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 24
Total : 2,651
