Aller au contenu principal
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
20 questions Voir tout
My external drive won't appear on my desktop
I have a 5TB Seagate Backup Plus that I was using out of the norm (as an Xbox One hard drive) and it just stopped working late last year after a storm. The hard drive turns on as normal, but I can’t pull it up on my desktop, Macbook, or game console, and the power indicator light keeps flashing. I plugged it in today, after months, and it started pulling up again, but not for long. 10-15 seconds at best. I’ve had this thing since 2015 and would hate to throw it out, any suggestions?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
People, STOP buying these "ready-made" external hard drives. Most of them use proprietary interfaces so you can't replace either the drive (to upgrade to larger capacity or an SSD) or the case/electronics.
Buy a separate external case with a USB 3.1 interface. They work with ALL standard SATA 2.5 inch SSD and HDD drives. Yes there are also one for the 3.5 inch drives.
Some are even waterproof (to a certain degree), shock proof, accept 9.5 and 12.5 inch drives and are simple quick opening cases. Oh, and much cheaper than the WD, Seagate, etc.
Then you can either buy a standard or use a spare drive lest over from an upgrade.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Sadly it does sound like its time to shed a tear. Mechanical drives do wear out.
You should get a good surge suppressor for your system and its peripherals. A good zap could do you in as well!
Indice 2
Ajouter une réponse
Jerson Ruiz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 99
