Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mise à niveau de la Nintendo Game Boy Advance, l'Advance SP est sortie, en Amérique du Nord, le 23 mars 2004 avec une structure carrée et un design à coque.
Nintendo Gameboy Advance SP Not Charging
I have the same problem. I check the output of the charger and I got 6.2 volts (the charger says the output is 5.2v). I remove the back panel and check again the charging port with the charger attached and there's a 6.2 v reading, but when I checked the battery terminals, there is no measurement at all.
Based on the test that I made, I conclude that the problem lies in the circuitry between the charging port and the battery terminals. I think the best solution to our problems is to bring our GBA SP unit to nintendo authorized dealer for repairs (if it's worth the cost).
Update
@ oldturkey03:I didn't clean the battery contacts since there is a resistance on it. I didn't see any fuse inside of the unit.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
2 commentaires
Those would be SMD items, did you check the picture. Look for the "F2" etc. on your logic board.
par
What is your model number on this? You will find it on the bottom of the case. The model number is either going to end in 001 (the original one) or 101 (New Brighter Screen). When you plug the charger in does the charging light briefly flicker (turn on then off quickly) as you plug it in or does it remain off ?
par
Ajouter un commentaire
2 Réponses
Solution retenue
Same answer as here only because your answer was converted to a separate question. " Just for kicks and giggles, has any of you two tried to clean the battery contacts. make sure that the contacts are actually getting to the battery and check the fuse as well. I would do that before trying to send it off."
Indice 9
5 commentaires:
+ Gee I guess it getting changed to a new question is a good thing since the issues and participation are a little different. This person deserves our attention. You have given a good answer.
par
Thank you ABCellars. Somehow we should get people to ask their own questions. This way they will realize that they do get their individual answers and issues do not get confused or even forgotten.
par
I totally concur. However I believe %*$* will freeze over before most people will willfully take their number and not ditch in line if they think they can get away with it.
par
I know. It does get frustrating. Always remains me of forums that are so hard to navigate and to follow your own question. Typical, me too attitudes...;-) We'll just keep picking away....
par
i have this problem too but it turn on but doe's not charge can you help me on that
par
What is your model number on this? You will find it on the bottom of the case. The model number is either going to end in 001 (the original one) or 101 (New Brighter Screen). When you plug the charger in does the charging light briefly flicker (turn on then off quickly) as you plug it in or does it remain off ? (copy and paste to question)
this is happening to my deice when it flickers on the charge what does that mean
Indice 0
Ajouter une réponse
teamgshock1 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 53
Total : 33,236
