Aller au contenu principal
General repair information on LG washing machines.
Questions au sujet de 12 Voir tout
Why is my machine getting an OE error between each cycle
Hi, my LG front load washer/dryer won’t complete a full wash. It stops with an error message ‘OE’ at the end of the washing cycle, I then turn it off and change it to rinse and spin only and it rinses but then same thing happens at the end of the rinse cycle and so on. Obviously something wrong with the drainage, no kinked hose, clean filter and the pump is working because it will drain the water away once turned off and the cycle changed manually to the next step. Is this an issue with the computer….?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
I’m having the same problem. I’ve replaced the drain pump, inspected all the lines, and replace a couple of valves already, but nothing has worked.
I see this happened to you almost 2 years ago. Did you figure out what was causing it?
Hopefully this will help me with my issue.
Thank you
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter.
Indice 1
1 commentaire:
Thanks Mayer. Yes I googled it and checked both of those things, they're fine. Also, the water will empty once the machine is turned off and on again and set to the next step manually.
par
@lauren_h since you already checked the obvious it is time to dive in deeper. Could be a drain pump issue as well as a main circuit board. Check this out next
Indice 1
Ajouter une réponse
LaurenHollingsworth sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 120
Total : 2,326
