Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
5 commentaires
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
par jayeff
I can pry the whole thing off, its just that part in the middle that is holding onto it.
par Braxton Biggers
what screwdriver did you use to open the screws?
par bobby
Maybe the screw is under the keyboard. Take out keyboard and have a look.
par mike
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
par stressmaster
