Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Système d'exploitation Android 4.4 avec une résolution de 1600 x 2560 pixels.
rear cover cable cut
Hi ….. my sister has Samsung Tab s 8.4 (SM-T705) …. and when she was trying to unpack the rear cover of the phone she cut some cable glued between the device and cover, I didn’t what this cable for.
the cable labeled by KL_LTE_MAIN_Rev.09 L
so I need to know the cable is it important or not …. what should I do if it’s important
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
I don't see a cable. It looks like it has contacts that “make contact “ when the case is closed. Probably to let it know that the back cover is closed. From what I see there is no cable and it should be
Update (06/02/2020)
There is no cable. It has contact points on each side that makes a connection when the case is closed. Nothing is missing. No cable is damaged. It's
Indice 1
1 commentaire:
you can see in the last photo something labeled with KL_LTE_MAIN_Rev.09 L, I don't if it is cable or not, but what I know it cut off
I think it's something related to the LTE antenna?
par
Ajouter une réponse
AHMED OM sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 283
