Aller au contenu principal
Le Toshiba Satellite C655D-S5084 est un ordinateur portable milieu de gamme qui fait partie de la série Toshiba Satellite C650. Le C655D-S5084 est une version personnalisée du modèle de base.
10 questions Voir tout
Black screen of death
I got a broken toshiba satellite c850 that was faulty, the black screen of death came when i tried booting it, but it worked when i renoved the cmos and put it back in. A few days later it gave me the black screen of death again, i have already tried the basic troubleshooting including the discharge trick whatever its called, i have tried holding in the loose stick of ram, replacing the cmos battery and so on but nothing! Please help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Bryn,
Have you tried connecting it to an external monitor or TV?
If that works then loose cable to screen or defective screen.
That model is from 2011. Remove the CMOS again but this time replace it as it is probably not holding it charge.
When you do get it going agian, this time, update the BIOS. Should be v6.20.
https://support.dynabook.com/support/vie...
It can be updated from Windows or use Rufus v3.11 to make a bootable USB flash drive from the “iso” file.
Hope this helps!
Indice 1
5 commentaires:
Already done, lo luck
par
I tried the other methods but it gave me nothing...
par
@theandroidkid
Did you update BIOS?
par
How do i do that?
par
@theandroidkid
Hi Bryn, I just updated the 'Answer" to help with the BIOS update. Take a look.
par
Ajouter une réponse
Bryn Trainor sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 648
