replaced battery and now touch screen doesn't work.
touch screen doesn’t work after replacing battery. Tiny screws may not be in the right place but everything else works
If you put the wrong screw in it can damage the motherboard and cause touch not to work. It's called long screw damage. Look down the screw holes and see if you see copper. I believe the long screw is on the top right spot. You can try checking the connections and make sure they are tight and clean. Clean the connection with alcohol
It could be the tristar ic which controls charging and data transfer. Take it to a repair shop and have them test it, it only takes a couple of minutes and they usually won't charge you for it.
I had a new screen installed and new battery and it worked fine...for 2 minutes and then shut off and started to reboot whereupon it came up for two minutes and shut off again. The battery would not charge past 9% so another new battery later the same thing happened except now it stayed at 8%. The charging symbol appeared but charging didn't happen after "charging" all night. So now I have an android phone I don't like much but still want my iPhone 5SE back. what to do now?
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 173
