Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La montre connectée quatrième génération d'Apple, avec connexion aux réseaux mobiles en option, mise sur le marché le 21 septembre 2018.
Power button is stuck
I have an apple watch series 4 that has the power button stuck pressed in. I had a protector cover on it that I never removed and it may have built up dirt and grime over time. I tried cleaning it around the edge of the button with a toothbrush and some water to no avail. When I connect the watch to the charger the apple icon comes on for a few seconds but then turns off due to the power button being stuck.
Répondre à cette question J'ai le même problème
Indice 7
Ajouter un commentaire
3 Réponses
Réponse la plus utile
+1 for rinsing for a minute under warm water, which worked for me.
Context: after several days of swimming in salt and fresh water over the course of a week, after the last dip, the power button seemed to be stuck, going into Emergency SOS mode over and over again. After a reboot, the button was still stuck, so it could not boot: it would show the Apple logo for a few seconds then reboot again. Washing under warm water and clicking the button repeatedly fixed it.
Indice 3
From others who have had this issue, it looks like you can carefully rinse it under warm (not hot) water from the tap. Maybe this would remove whatever is causing the stick?
Indice 2
I had this exact same problem after using the SUP case. I found a local iPhone repair shop that was able to replace the power button and the clicking mechanism beneath it and the watch is like new again. Hopefully you can find someone willing to give it a shot!
Indice 2
5 commentaires:
The same thing just happened to me with a Supcase. What did they charge for the repair.
par
Same here with the Supcase I wouldn’t recommend the case for that.
par
Same! SUPcase! Dang!
par
Same thing is happening to me. Also had in a SUP case.
par
The repair cost about 50 bucks I believe. Unfortunately maybe a year after that the battery started to die almost immediately and I had to get a new watch anyways.
par
Ajouter une réponse
Freddy Gomez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 96
Total : 17,234
