Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Seconde génération d'iPhone. Modèle A1241 / capacité de 8 ou 16 Go / dos en plastique noir ou blanc. Sa réparation est plus simple que celle du premier iPhone. Nécessite des tournevis, un outil pour ouvrir et des ventouses.
Doing a repair and ripped something. Is it important?
So I’m bought an old iPhone 3 and was checking the motherboard. While i was taking off the metal protectors, one of these metal things broke (see picture)
Was wondering if they were anything important and how to fix it if it is or if I can just leave it like that
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
Picture is not clear. Looks like it is just bent. Where is it broken?
par
Added a new pic. I’m just worried because it looks soldered on and I’m not too good with soldering
par
Hi @coolmanguy124
Was the phone working or not before you opened it?
Just trying to understand why you opened it.
What were you checking on the motherrboard?
par
Ajouter un commentaire
2 Réponses
Solution retenue
I would say that the lifting metal bracket provides more structural support for the phone and to protect the motherboard as well. In some devices its not uncommon to have a small rubber sticker on top to hide the components underneath. Take some submarine UV glue and gently apply it to the corners of the brackets.
But in future reference, never forcefully disassemble anything. If it doesn’t easily move then check for hidden screws. Never pull only gently lift.
Indice 0
You could glue it down instead of soldering as it is not a circuit. It does have to be flush otherwise the phone will not go together properly.
Indice 0
Ajouter une réponse
coolmanguy124 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 20
Total : 425
