Aller au contenu principal
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Questions au sujet de 120 Voir tout
Screen not interacting after battery and force touch gasket replacemen
Replaced battery Series 1 due to bulging and also force touch gasket. Charges fine and repaired without issue. But no screen response to touch. Did not replace screen as it was fine. Broke everything down and reconnected battery and force touch connection. Still no luck.
Should I try again with a new force touch gasket? Do I need to detach and reattach screen?
Thanks for your help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Thanks Justin,
Just replaced the screen and that was it!
Thanks for the expert help and saving me some money.
par
Ajouter un commentaire
1 Réponse
Solution retenue
I’ve repaired several Apple Watches, but have never had touch issues with them. To my knowledge, the force touch gasket is only responsible for the “3D Touch” functionality of the display, not the touch itself. I’ve had watches where I broke the gasket but it would function without it. Since you already tried reconnected the screen, I don’t think it is a connection issue. The only guess I would have to what happened is perhaps the swollen battery pressed on the bottom of the screen and broke the touch functionality, or perhaps some damage occurred during the repair. You could try with a new force touch gasket as it would be the cheapest solution, but personally I don’t think that would fix the issue. It is likely an issue with the screen assembly itself.
If you want to try a new screen, perhaps try looking for iCloud locked series 1 watches on craigslist/facebook marketplace or eBay. It might be cheaper to buy a locked watch to salvage for the screen as opposed to just buying a new screen.
Good luck!
Indice 1
Ajouter une réponse
James Christiansen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 49
Total : 1,759
